5 axis mach 3 post process
Message 1 of 25
i have problem post post processing mach 3 ,  5 axis .
in my post i editor i get this error ( brackets currently only supports utf 8 encoded text )
does anyone have solution
thanks .
Replies (24)
Message 2 of 25
LibertyMachine
That's been known to happen from time to time. I don't think an exact cause has been determined. The last (and only) time that it happened to me, I changed the editor to Notepad. Opened up Fusion, punched out a program into Notepad. Went back into Fusion and rest the editor to default and it worked fine
For the editor, go into preferences>CAM. It's at the top
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 25
i just did that and i got ( Warning: Work offset has not been specified.
Using G54 as WCS.
Error: Tool orientation is not supported.) error.
is it possible at all to post proces 5 axis for mach 3 ?
thank you for reply ..
Message 4 of 25
daniel_lyall
@Anonymous what post processor are you useing the default one, the 4 and 5 is not turned on.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 5 of 25
i am using default post proces as it is under post configuration ( generic
mach 3 mill ) .
if i post proces same program for hass umc 750 . there is no problem .
i do not own hass mashine to try it but on code it seems all right .
Message 6 of 25
daniel_lyall
The umc is a 5 axis machine by default it's set to 5 axis B and C.
I can give you a post that has the A and B axis turned on I don't know How to use 5 axis only 4, or stick with the haas one I can change the mach3 one to b and c or a and c what ever.
@LibertyMachine back to you do you know 5 axis stuff.
Daniel Lyall
The Big Boss
Mach3 User
Message 7 of 25
LibertyMachine
Negative, sorry. I'd suggest asking on the Post Forum about implementing 5 axis motion on the Mach post
Seth Madore
Message 8 of 25
daniel_lyall
@LibertyMachine thank you I have a post he can have, that's upto the op.
Daniel Lyall
The Big Boss
Mach3 User
Message 9 of 25
can you send me that post ?
and can you do some instructions on how to change those axis
Message 10 of 25
daniel_lyall
If you go here http://forums.autodesk.com/t5/hsm-post-processor-forum/bd-p/218
There is a post about setting up the post prossesor (I cant give you the page it's on the hsm forum is blank for me) for 4 and 5 it says about setting the angles and stuff all what you will need to know.
the attached post has the A and B turned on
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 25
hi.
the solution you gave me Works super !!!
i just copied the cps file you send me into direction where fusion 360 has its other post processors so now if anything dues not work corectly i can stil chose old mach 3 post processor .
buit anyway i tried your solution and it Works great
thank you very much .
Message 12 of 25
daniel_lyall
OK just be careful you should still go in a set the angles for the B axis
Daniel Lyall
The Big Boss
Mach3 User
Message 13 of 25
ok thanks .
Message 14 of 25
Im having an issue with mach3 and my 5 axis mill. I have tried all the post processors that ive come across on this forum and have even tried to edit my own. no luck. I have a chinazone cnc 6040 5 axis mill. the post processor is where all my issues lie i think. I am able to generate the g code for the 5 axis job. when i post it and load the g code i get the infamous "bad character in code" in mach3 when i load the same g code into the online NCviewer.com it looks a lot better but i can tell that the b axis will crash when rotating to the next surface. long story short, i think that if someone happened to have a post processor that worked for this machine or even something close...ill be a lot better off than the mess im in now. thank you for your help :]
Message 15 of 25
daniel_lyall
You need to set the range for the axis it is in here how to do it
https://forums.autodesk.com/t5/hsm-post-processor-forum/how-to-set-up-a-4-5-axis-machine-configurati...
 like below this will only let the b axis go from -180 to +180
var bAxis = createAxis({coordinate:1, table:true, axis:[0, 1, 0], range:[-180, 180], preference:1});
What is the bad character you are getting.
Can you start anew thread for this and post a model that has this problem and a sample G code.
Daniel Lyall
The Big Boss
Mach3 User
Message 16 of 25
Hi
i have working 5 axis post procesor for 5 axis mill
construction is table- table
meaning all additional axis are on table ...
i tested it on mach 3 but on a specific version .
i have had no problems at all and i run realy big programs
like 6300000 lines or more
also since fusion team added new option as select mashine type in creating
new setup
it realy helps a lot when doing 5 axis cam
if you want i cant send
mach version and post process.
since we are looking for solitions i am working on how it would be possible
to export g code for 5 axis robotic arm with stepper motors ...
i could use some help there .
Message 17 of 25
Awesome! Yeah can you email me the mach3 version and post process?
I'll give it a try
[email protected]
I'm using mach3 Version R3.043.066
@Anonymous wrote:
Hi
new setup
Version R3.043.066
Message 18 of 25
daniel_lyall
@Anonymous it is requmended to use version R3.043.062,  R3.043.066 has some bugs in it that can make a machine crash.
Daniel Lyall
The Big Boss
Mach3 User
Message 19 of 25
Can you send me the 5 axis post processor for Mach 3?
Message 20 of 25
no problem 🙂
just send me your mail .
