5 axis chamfertoolpath
Paricla
Message 1 of 10
Paricla
I'd like to chamfer some parts using our 5 axis machine. But somehow I can only get a 3D trace toolpath to work a bit. But then I can't reach tighter places.
Isnt there a 5 axis chamfer toolpath? Something like the following : https://www.youtube.com/watch?v=d1pRulUDWCE in Fusion360?
I somehow can't figure it out.
Thanks in advance
Patrick
Replies (9)
Message 2 of 10
ChristopherMarion
Hi @Paricla
I have not tried this with Fusion, but I think a Swarf may be able to do something like this.
You may need to construct some surfaces where you want to drive the tool though.
Here is a quick stab at it.......
Please don't mind the collision warnings 😊
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Message 3 of 10
Paricla
seems to work indeed!
Message 4 of 10
ChristopherMarion
Hi @Paricla
Glad to hear this worked for you.
Please accept as a solution so others searching for this option can read through it.
Cheers,
Christopher Marion
SolidCAD - Canada
Message 5 of 10
DarthBane55
I wonder if, using a ballmill, one could use multi-axis contour.  You'd have to remove the modeled chamfers and pick the sharp edges I think.  I might try that later because it could be handy at times.
Message 6 of 10
ChristopherMarion
Hi @DarthBane55
Yeah, should work if you are trying to break edges.  You'd need to machine in negative thickness I'd imagine.  I use a similar toolpath in PowerMill for trimming.....same idea.
Christopher Marion
SolidCAD - Canada
Message 7 of 10
DarthBane55
@ChristopherMarion
Just curious, if you have PowerMill, why do you use Fusion?  I would imagine that for simpler job, it's just faster to use, but anything else?
Message 8 of 10
ChristopherMarion
Hi @DarthBane55
I'm a Technical Specialist for an Autodesk reseller.  I use PowerMill, FeatureCAM, PowerShape and just starting to get familiar with Fusion.
I've used PowerMill for a very long time as a programmer and as a specialist with Delcam and Autodesk.  Really liking Fusion at it's current state and know its going to get much stronger.  Exciting times!
Christopher Marion
SolidCAD - Canada
Message 9 of 10
DarthBane55
Haaaa yes, I see it now, SolidCad, I might even have talked to you once!  That explains it then, thanks! 😁
Message 10 of 10
How did you construct these surfaces? Do you maybe have an example file for me?
