3D Tool path Parallel issues
Hi Everyone. I am new to Fusion and Cam. I have successfully cut a hand full of item on my cnc mill using 2d tool paths. Worked great. Very straight forward. Then i got an idea to "Engrave" designs on the material. Was wanting to do cross pattern design using 3d Parallel tool path. Creating small rectangle tool paths. I was wanting to cut .03 deep into the top of the part with this design. I can get the cross pattern tool paths to show in cam but they don't actually cut the model during simulation. Even when the bottom heights is set to model bottom. It shows the tool path ramp up the side of the model but it stays perfect flush with the top of the model. Hope that made sense. It should be cutting through the stock for example if the bottom heights is set to model bottom. I am just playing with a 2" wide x 4" long x .5" thick stock sample. No special design. I feel like i am missing a button to click or something like that. Any ideas what is going on? Thank you ahead of time!!
Josh
