3D surfacing tool path not producing arcs - HELP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm programming CNC milling in fusion and I'm using 3D contour and 3D ramp and I can't get Fusion 360 to create arc tooth paths. It keeps creating small linear moves. I've messed with smoothing and tolerances to see if I could force it to create arcs and I just can't get it to work. The part I'm machining is a circular boss with draft. I have to use a surfacing tooth path because of the draft. The model is imported from CREO as a solid STP file. I've recreated the boss with draft in fusion to see if it was something to do with my imported STP file and the same thing happens when I program a 3D contour and 3D ramp. I originally thought it was my post for my Hass TM2P but I started to look at the tooth path data within fusion and noticed they were linear moves, not arcs.
Any help would be greatly appreciated! I really just want smooth surfaces!
