3D Surface Strategy
3D Surface Strategy
Message 1 of 11
3D Surface Strategy
Hi everyone.
I'm trying to use a ballnose endmill to create a rounded edge along a pocket. the problem I'm having is getting the tool to machine away the entire rounded contour. For some reason, the tool will not wrap around the profile. I've tried several things, to no avail.
I've attached the file.
Thank you
Replies (10)
Message 2 of 11
LibertyMachine
In your Setup, you have an issue. There is a missing body and I think that was contributing (but not the entire cause). I knocked out a quick screencast that will show you what I've done to achieve the results in the attached part:
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 11
That is basically what Im looking for.
What were the mistakes I had made.
Message 4 of 11
LibertyMachine
See above edit
Seth Madore
Message 5 of 11
you've certainly pointed me in the right direction.
Thank you
Message 6 of 11
LibertyMachine
Great, glad I could help!
Seth Madore
Message 7 of 11
Since you're mind is on the subject, would you know how I could get the tool to start at the bottom of the profile and machine in the Z+ direction? It's easier to maintain the correct cutting conditions, plus its less load on the tool.
Message 8 of 11
LibertyMachine
I agree that it is better conditions. However, the Scallop has one method of reversing, and it don't work really well:
Seth Madore
Message 9 of 11
The only problem is all the extra retracting.
i guess I'll keep my fingers crossd for an update.
Message 10 of 11
Selecting "other way" on the passes tab works actually.
Message 11 of 11
LibertyMachine
Yeah, I feel like a noob. Forgot about that "Outside>In" switch
Seth Madore
