3D pocket step down passes wrong?
j2
j2
Hi Forum,
using 3D Pocket to machine a 12 mm deep area I set max. roughing stepdown to a greater value (20 mm).
But Fusion still calculates a toolpath with more than 1 step, see attached screenshot. What´s wrong? Do I have to control the issue in another way?
Thanks for help.
Regards, Jörg
Marco.Takx
Hi @j2,
When possible use 3D Adaptive. This operation is much smarter in this case
The Pocket operation uses that Flat Area to make that extra stepdown.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
j2
Hi Marco,
thanks. Well, I do use adaptive in the prior operation with stock left. The pocket operation is for a clean finish, which can not be provided by adaptive on the radial side.
Any idea, why pocket behaves the way as does?
Regards, Jörg
Marco.Takx
Hi @j2,
I’m not behind my PC, so I can’t check now.
You can share your model so someone can take a look at it?
If it isn’t possible, split the operation into 2 operations.
Marco Takx
