3D horizontal - can't find maximum stepdown
rumpelstielz
rumpelstielz
hello, i am trying to find the option to do several passes in the 3d Horizontal operation. It even mentions the 'optional maximum stepdown' feature but i can't ind it and ther is no multiple passes option neither.
Screen Shot 2016-06-17 at 12.51.53.pngScreen Shot 2016-06-17 at 12.51.59.pngScreen Shot 2016-06-17 at 12.52.04.pngScreen Shot 2016-06-17 at 12.52.12.png
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
HughesTooling
I think you need to tick the Axial passes option.
Mark
Mark Hughes
Owner, Hughes Tooling
jeff.walters
If you’re wanting Horizontal to cut down the sloped faces it’s not going to happen. Horizontal will only cut flat horizontal faces. For that sloping face I would recommend Scallop, Parallel, Contour, or a combination of Parallel and Contour.
Jeff Walters
Senior Support Engineer, CAM
rumpelstielz
yes thanks Mark it was th axial options i hadn't seen.
Jeff, you're right, just figured this out as well, i wanted to use this as a roughing operation which doesn't work in this case.
