3d contour toolpath creating tons of extra wasteful moves
infoEMRZJ
Message 1 of 11
infoEMRZJ
I've tried looking for other posts with similar problems, and haven't had much luck.
I'm using a ball endmill to add a chamfer to a part that has some oddball angles.  In a couple locations, there are ton of extra wasteful moves, and I'm trying to figure out how to reduce them, as they add a ton of time.
I've added a sample part with a small chunk of my part to demonstrate what I'm trying to do.
Reducing the tolerance obviously helps, but this is a finishing pass, and I'd rather not reduce the tolerance.
Replies (10)
Message 2 of 11
HughesTooling
When I open your file all reference selections are lost in the setup and all ops. Can you test your file and fix the selection please?
Mark Hughes
Owner, Hughes Tooling
Message 3 of 11
seth.madore
Oh good, I thought I had done something on my end, what with all the Fusion builds and all the other stuff I've been involved with lately...
Seth Madore
Message 4 of 11
seth.madore
How about a Flow(Preview) toolpath?
Turn on the Flow(Preview) toolpath in your Preferences and select the surfaces you want to machine. Since the holes aren't in yet, you could either make a Patch surface that blocks them up, or duplicate the model and delete the holes
Seth Madore
Message 5 of 11
infoEMRZJ
That's super strange.  I don't understand why it's happening, or how to fix it.
I tried downloading the file from my previous post and importing it, updating all of the selections and toolpaths, saving, exporting, then re-importing, and it lost all of that information.
Any ideas?
Message 6 of 11
infoEMRZJ
That does look quite a bit better.
I can't get my flow toolpath to look as nice as yours though, and I'm not sure why.
It gives me a "one or more passes were partially skipped" warning, but doesn't tell me why.
It also does some weird stuff down in that inside radius
Message 7 of 11
infoEMRZJ
Tried with a different file, this one appears to keep my selections.
It also has that flow toolpath
Message 8 of 11
seth.madore
It's your Surface Triangulation Tolerance. Right click on the toolpath and select "Compare and Edit". Type in "Triang" and change this to *.05
After that, recalculate your toolpath
Seth Madore
Message 9 of 11
infoEMRZJ
Alright, that helps, thank you.
Unfortunately on the full sized part (I'm not able to share the file with the whole part), this flow toolpath makes a ton of rapid moves, and ends up taking like 25% longer than the 3d contour path
edit:  Is it possible the machine time estimator is incorrect?  It seems odd that this would be slower, looks like the 3d contour path has similar number of rapid moves
Message 10 of 11
seth.madore
Can you share your file privately?
Right click on the file in the Data Panel and select "Share Link". Copy that link and email it to me:
seth DOT madore AT autodesk DOT com
Seth Madore
Message 11 of 11
infoEMRZJ
I sent you an email a while ago. Since then, I've tried adding patches to the holes, and the flow toolpath doesn't seem to recognize them at all (yes, I selected those patch surfaces in the geometry tab).
