3D contour Contact Point Boundary not working?
Tbaker25
Tbaker25
Ok guys, I've been struggling with this one. Am I missing how this is supposed to work, or is this a bug?
I'm using 3d Contour to finish some specific areas of a part. I've used Touch Surfaces to accomplish this, rather than a machining boundary. However, it is rolling around and machining more than the selected areas.
Here is the path it generated. It rolls past the edge of the selected surface.
From my tests, Contact Point Boundary does not affect the generated toolpath at all.
Tool center/inside boundary works only for the outer edges of the part. It's behaving like contact point boundary only respects machining boundary selection, not touch surfaces. This is in contradiction to the help document http://fusion360.autodesk.com/learning/learning.html?guid=GUIDA16162AB-95D5-4086-B54D-926B9A9BB429 which says
"Select a face / faces as the boundary for a 3D finishing operation.
Selecting a face (or multiple faces) as the boundary for a 3D finishing operation provides an efficient way of limiting where the tool is machining."
Any ideas what I'm doing wrong? Thanks!
Tom
LibertyMachine
Any chance we could entice you to export and share your .f3d file?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Tbaker25
Could I email it to you directly? Proprietary et al.
LibertyMachine
yes, but I won't be able to really do much with it until this evening. Hot job with a 2 minute cycle right now.
libertymachineshop
at
gmail
dot
com
Seth Madore
Steinwerks
I can take a look at it this evening if @Anonymous is too busy. I'll PM you my email if that works.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
LibertyMachine
Yeah, it's looking like my night is going to be too busy. Grab it if you don't mind @Steinwerks
Seth Madore
Tbaker25
Thanks for the help, guys.
I appreciate you looking at my file.
I'm posting this directly to you and back to the forum for others to learn.
I spent another few hours trying to reverse engineer how this is handling it. I think it boils down to this:
Contact point boundary works fine for actual machining boundaries. Fusion doesn't see "Touch Surfaces" as a boundary for this purpose. Therefore, any attempts to constrain machining to only selected surfaces must be done via machining boundary.
I've seen no particular change in the z-axis behavior between contact point boundary on or off.
I think where I was lead astray was in the documentation where it referred to "Selected surfaces" for contact point boundary.
Tom
