3D Adaptive: Need some advice
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to ask the community for some advice. I more or less just started using Fusion 360 and facing obstacles I don't know how to handle. This time it is about the 3D Adaptive milling strategy. Both questions I've got are not really heavy problems but in order to learn Fusion 360 CAM I wonder how to overcome them. I attache the project file to this post so you can - if you like - take a look to the operations.
So here we go:
1. Material left over after milling (1st operation)
Every now and then I get areas where the 3D Adaptive milling strategy does left over some material. Please see the screenshot below. The area is marked with a red arrow. I know it is very very thin but I nevertheless would love to know if there is anything I could do to get Fusion not leaving over that material. What you see in the screenshot is the result after the first operation has finished.
2. 3D Adaptive Rest Machining (2nd operation)
Marked with red arrows you see in the screenshot below the areas where the tool is not reaching the bottom of the pocket as I want it to do. It leaves over 0.9mm more than I want it to do. Both operations, the former one as well as this one are configured to leave 0.1mm stock axial. The first operation does what I want it to do but this second one doesn't and I have no idea how to get it to not to leave even more stock there. Marked with green arrows are the areas where it does leave over exactly the 0.1mm as I want it to do. Very strange to me...
Well, I would highly appreciate if someone could help me figuring out how to overcome these two things, thanks.
