- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to create a simple 3D adaptive clearing operation to rough out the 2 cylindrical bores here. The path starts out OK, spiralling down, then clearing out the material in 2 passes. Then it starts endlessly jerking in and out of the holes. I've tried changing all the parameters relating to smoothing, tolerance, tool containment, staydown etc (and many more besides) but I can't get these endless retract move (yellow) to go away. I started with pretty much standard settings. For the geometry I used "machining boundary" and selected the 2 circular outlines at the top of the holes and chose "tool centre on boundary". For my heights, I have the bottom set 1mm below stock bottom and top is 1mm above model top.
Can anyone suggest what is going wrong here? This is one of those conFusion problems that comes up with the CAM settings. I expected a simple(?) 3D clearing op be fairly straightforward but I'm up against a brick wall here.
Thanks!
