3d adaptive clearing fails to clear center
etfrench
Mentor Mentor
Message 1 of 12
etfrench
Video attached.  The simulation doesn't show anything left above the model top, but the center was not machined.
ETFrench
Replies (11)
Message 2 of 12
LibertyMachine
Without seeing the .f3d model, it's not going to be the easiest issue to diagnose. Would you be willing/able to share it? To share:
File > Export > Save to local folder. Return to thread and attach the .f3d in your next reply
It could be several things:
Tool size not as described in Fusion.
Machine accuracy (although I doubt that one)
Incorrect selection
Incorrect stock/model selection
And lastly, it could very well be a bug, but we won't know without seeing
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 3 of 12
etfrench
Here's the model.  The toolbit is specified correctly.  The machined part is the correct size within .0005".
ETFrench
Message 4 of 12
LibertyMachine
How wide is the left over material?
Seth Madore
Message 5 of 12
etfrench
About .0625".  I stopped the video just before the end of the tool path.
ETFrench
Message 6 of 12
Laurens-3DTechDraw
Are you sure you gave in the correct diameter tool?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 7 of 12
etfrench
The bit is .125" diameter made by Kyocera, so I'm reasonably sure it is specified correctly.
ETFrench
Message 8 of 12
Steinwerks
Looks like deflection on the last pass. That's not exactly a 50-taper VMC.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 9 of 12
RandyKopf
@etfrench
So your initial message reveals where to look first. That is your simulation shows no rib left. Yet the cut part does.
So looking at the video I'm surprised you had partial success cutting that part with that light work holding. I would agree with @Steinwerks that it is deflection.
I would assert it is not the tool that is deflecting... it is the work-piece is moving.
Try to find a better way to secure your part. Is there a way to verify IF the part actually moved?
Randy Kopf
http://desktopartisan.blogspot.com/
If my post is helpful, press the LIKE Button If it resolves your issue, press Accept as Solution! Have a great day!
Message 10 of 12
Steinwerks
I didn't even notice it was being held by double-sided tape until @RandyKopf pointed out the workholding. Milling rigid materials requires clamping force.
If tape is all that's available, the stepover needs to be lessened drastically.
I will also add that the deflection in the cut can easily be seen in the floor finish of the part. This is a very small cutter in a very light machine and it's very visible.
Neal Stein
Find me on:
Message 11 of 12
etfrench
It's the first time I've tried the technique of using normal masking tape with CA glue between the layers.  I don't see any signs of deflection in the circular pocket or the outside dimensions of the part.  Perhaps the adaptive clearing is putting more side force on the piece.
ETFrench
Message 12 of 12
xander.luciano
Hey,
Looks like you might be missing that last pass? Your adaptive settings are set to be .050" of engagement, so if the remaining material is .0625" ish, you might be missing this last portion somehow.
o8ohYS4
Best,
Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
