3D adaptive clearing crash
jimmy.haddersPKDBD
jimmy.haddersPKDBD
Hi, so i've used fusion now for a good while as my main CAM program here at work, and all the time it has delivered really good toolpaths. but i think i've found a bug where it instead of lifting above material it crashes right through it, the only way to get around this atm seems to be to add a lift height so that the tool passes above the workpiece before going into the next cut.
This has never been needed before and fusion doesn't tell me that it is a crash either.
LibertyMachine
While it does indeed appear to be an issue and definitely in need of reporting, there is another solution to making it NOT do that. By actually selecting a contour for machining, I found that the toolpath came out as expected:
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
jimmy.haddersPKDBD
That seems like a probable workaround for the moment.  But it bugs me that a function that i kind of started to rely on as really reliable bugs out and doesn't warn or anything.
Anyhow, thanks for the workaround 🙂 I'll hang around to see if it'll get fixed and change to accept as solution then 🙂
LibertyMachine
Please take a moment to fill out a bug report. With the screencast and forum post already made up, it won't take but a moment of your time and it will assure that this issue is seen by those that matter
http://forums.autodesk.com/t5/design-validate-document/how-to-report-bugs-amp-issues/td-p/5722215
Seth Madore
jimmy.haddersPKDBD
I've sent an email to the applied address with a link to this post now. hopefully it'll get resolved quite soon.
LibertyMachine
"Quite soon" is a relative term in the software world. If something is downright broken, it (often) gets looked at quickly. If workarounds exist, they tend to get kicked off for a bit while more pressing matters are attended too.
Seth Madore
jimmy.haddersPKDBD
I've got a cam support ticket and it'll be looked on in the future. I'm not sure if i should accept this as a solution but at least the issue will be handled in the future after more pressing problems/bugs, just as you sais 😉
Anywho, at least there's the workaround you demonstrated for the meantime.
