2D Trace wrong compensation
kanokwan25310104
kanokwan25310104
I am trying to cut 2D trace by Ballnose and I found that the compensation is not correct, it is cut to inside the workpiece but I want cut only on profile. I try to find How to solve this issue. Any suggestions wold be appreciated.
programming2C78B
Please click "Accept Solution" if what I wrote solved your issue!
kanokwan25310104
Thanks for your answer. This is not my question, If you see at the start and end point you will find that the ball nose is go inside the workpiece at the start and end point, what I want is the ball nose must only touch surface of workpiece or conpensate profile but these 2D command.
programming2C78B
maybe 3D parallel is more what you're after then, it will adjust the width of the arc as required.
Or manually draw the arc where it is the tool dia away from the model at the very bottom of the arc, and touching tangent on the center
