2D Pocketing glitch with the character 0 Haas VF4
Hello. Whenever I'm engraving my part (Pocketing the text), everything comes out fine except the character "0". The simulation, shows an invalid movement and cuts through the center of the 0, as well as making a circle around the outside. Simulation and machine movement are exactly the same. Toolpath I'm referring to is highlighted in yellow in the picture that was attached. Century Gothic Bold Text was used to create the pockets.
seth.madore
Please export and share your .f3d file so we can provide better assistance. To do that:
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply.
If the file contains linked component, the links must be broken. If the file cannot be shared due to privacy concerns, you can email me the file: seth dot madore at autodesk dot com
Seth Madore
Seth, I sent you an email. Thank you.
seth.madore
Turn Smoothing off. There are numerous issues with how it's calculating incorrectly. You will need to manually regenerate the operation, as that is also having a rough time of things. Select the operation and CTRL+G
Seth Madore
Thank you. That resolved the issue.
