2D Pocket with REST Machining
Hello -
I have a warning that I often get with 2D pockets. The warning is:
Enabled feature flags: setup-sheet-viewer
Warning: Skipping a pocket since the rest tool has not removed any material.
Generation completed with 1 warning(s) in 260.4ms.
In this case I am cutting stainless and successively use smaller endmills. I start with a 1/4" then use 1/8" and do a final clean up pass with 1/16". The first pass is just a clearing pass but I do not leave any radial excess material. I use a minimum radius of 0.0" on all tools (which may be a mistake). After I cut the with 1/4" I use REST machining with the other 2 cutters. Both have the Warning listed above. By the simulation it does NOT appear that it is miscutting the part. However, the Warning is not clear.
Is the Warning indicating that it is skipping one of the profiles or is skipping all of them? Should I be setting a different minimum cutting radius for each of the cutters? I assumed that it would calculate the minimum internal radius based on the tool diameter. Is this incorrect?
Joe.
