- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is anyone else having trouble with 2D Pocketing not generating toolpaths for the same pockets since the latest updates?
I use 2Dpocket to engrave my company logo into all of the parts we manufacture, I use this same logo and engraving on 40-50 different parts and we have run thousands of parts using this same toolpath.
I am trying to run some parts from a fusion design I have been running about once a month all year, I had to change a tool number as I already had the tool loaded from the previous job (I do this all the time, so it's not uncommon to change this particular program), but as soon as I generate the toolpath again it does not toolpath one pocket. I have tried to re-program that one pocket only with no luck. I was using a .dxf as the geometry, so it cut the logo into the part and then used the pocket as the pocket selection. But all I can get from it would be best described as a facing pocket that must be using the stock shape as its driver.
As I have already said I have a lot of parts with the same logo that are already programmed and running, so I am hoping this is a bug from an update that can be fixed, as I am not really looking for a workaround.
I have been using Fusion 360 as my sole CAD and Cam package since 2018 so I do know my way around it fairly well and have tried all the tricks etc that I have found over the years, I will find a workaround to get the job completed but it would be great if 2d pocket can function as well as it has in the past.
Cheers
