2D Contour - Transition moves perform with Cutting Feedrate
tayfun
Message 1 of 18
tayfun
Hello everyone,
Today I realized a possible bug on 2D Contour strategy. Maybe it's not.
I have made a CAM program on 24 May 2017. At this date, everything was like it supposed to be. But today I re-generate all toolpaths and I saw that transition moves performing with Cutting Feedrate which is very slow. If I don't re-generate them, it still acts like it supposed to be. (transition moves with lead-in lead-out feedrate.)
Transition paths show with green lines like Lead-in and out paths. But Fusion 360 considers "Cutting feedrate" as feedrate right after lead-out path unlike the date 24 May 2017.
Please check the simulation videos and keep your eyes on my mouse cursor.
Replies (17)
Message 2 of 18
Laurens-3DTechDraw
As a tip for the next time making a video might be a lot easier with Screencast which you can find here: https://knowledge.autodesk.com/community/screencast
You don't have to but it might be easier.
What you see here is a little tricky to get right and I know the developers aren't totally sure on how they want to work this out.
That move should at least be in lead-out feedrate, but possibly we need to use stay-down linking feedrate. (Not implemented in all Operations but maybe it should)
What speed did it use before the regeneration?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 3 of 18
tayfun
Thank you for the tip. I'll use it next time.
Before regeneration, it was same with lead-out feedrate which is 7000mm/min.And movement is Lead-Out. Please check the image. It's before regeneration.
Right now, as you can see it is 600mm/min. It causes to a lot longer cycle time.
Message 4 of 18
tayfun
As a temporary solution, I closed "keep tool down" option under "Linking" tab. It more/less reduced cycle time to same like 24 May 2017. But Z axis always move to "Retract Plane" with G0 movement as predicted. I think this is unwanted situation which causes unnecessary Z axis up&down movements and it is obvious there has been some algorithm changes since May.
I hope developers is going to put a textbox/checkbox/radio button under the keep tool down option to adjust transition feedrate instead derive it from cutting feedrate.
Message 5 of 18
Laurens-3DTechDraw
Yes! We need that.
Laurens Wijnschenk
3DTechDraw
Message 6 of 18
andypugh
I am not sure about the "Solved" tag on this.
It seems that 2D Adaptive still has non-engagement cuts at the rapid rate, but I would consider 2D pocket to be unusable at the moment when (for my current part) 90% of the time the cutter is not touching the work but is still moving at the feed rate. (Using rapid retract doesn't really cut it for me with my knee-mill)
Message 7 of 18
Laurens-3DTechDraw
I think the solved marking is due to the fact the question got answered.
Not that the problem got solved.
For that we will tag @cj.abraham to see if this has a ticket in the system still, and if there are any updates on it.
Laurens Wijnschenk
3DTechDraw
Message 8 of 18
bmxjeff
Any updates on this? I didn't see an Autodesker comment @al.whatmough.
Jeff Hooper (Owner)
Hooper Machine and Design
[X] AUTODESK AMATUR ORDINARY
Message 9 of 18
cj.abraham
Added CAM-9094 to allow use of non-engagement feedrate when using keep tool down.
Message 10 of 18
bmxjeff
Thanks! @cj.abraham
Jeff Hooper (Owner)
Message 11 of 18
Steinwerks
Oooh this would be really welcome! Thanks @cj.abraham!
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 12 of 18
Eric_E
Good idea, I hope the developers are motivated to do this soon. If not, could we at least get the transition move at the lead out feed rate as it used to be.
Message 13 of 18
Has this ever been fixed? (It has been some time)
I am using version 7.0.0.17442 and it is still 'transitioning' at the cutting feedrate!
I am working on a part here which has 18,000"(457,200mm) of transitioning....
Message 14 of 18
bmxjeff
@cj.abraham Any news : )
Jeff Hooper (Owner)
Message 15 of 18
I would love for this to be addressed.  80% of my programming is 2D contour and for 3 years I've been using a custom script to modify the nc code as a workaround.  I've spent hours trying to work it out in my post processor but was never able to come up with a solution.
Message 16 of 18
seth.madore
@bmxjeff this doesn't look like it's gone anywhere, sadly. Opening up the case again and asking if there is any chance for improvement.
Seth Madore
Message 17 of 18
Any update? (on CAM-9094)
Message 18 of 18
thekondrat
Hello @seth.madore
Do you have any news about  CAM-9094 ticket?
