Message 1 of 8
- Mute
- Permalink
- Report
I'm facing a weird problem. I have a component in whinch part of the outline is a spline. I need to insert tabs for keeping the piece in place during machining.
Insert tabs "by distance" works, but tabs positioning is not ideal. As it is not possible to move or delete those tabs, I tought the solution would be to insert tabs "at points".
Amazingly, it seems that Fusion does not allow the positioning of tabs on splines. On straight lines it is straightforward, but clicking anywhere on the spline contour does not result in anything.
Has anyone faced this problem ? Can you suggest any way to circumvent the problem ?
Cheers,
Luiz
