@engineguy написал (-а):IMHO There is nothing to "fix", it is working correctly
From the "user side", I see that this is not working correctly. I set the ramp angle to eg 45 - it doesn't use it. So this is a mistake.
Can developers take into account that "multiple depth" is activated and correct the formula?
Why would a user think about it and fix the default settings to "0" every time to make it work?
IMHO it is best to just use the Ramp and no Multiple depths
No. you are not right. This only works on high parts. On flat parts (of which most are) this is never used.
If the cutter allows a large angle ramp (eg 45) then it makes no sense to use a ramp without "multiple depth".
Using only the ramp we get much longer operation time. Example:
square with a side of 1m. thickness 50мм, maximum depth 25мм. If you use multiple depths, the path will be long = 4m + 4m + cos(45) * 50mm ~ 8.1m
If only the ramp is used(with max ramp stepdown 25) the path will be> 12m. which gives x1.5 machine time.
This is the reason why only the ramp is not used on flat parts - it makes one more pass along the contour.
