2d contour not machined warning
samgaddis
samgaddis
I'm having trouble understanding why I'm getting a warning on the 2d contour in this file: https://a360.co/2Rj4h14
I went through the forums and made adjustments to tolerance and leads, but to no avail. Any guidance on how to troubleshoot this?
Marco.Takx
Hi @samgaddis,
Can you post the warning and maybe picture(s) of the situation. Haven’t the posibility to open your file.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
samgaddis
 Sure no problem. Here's an image of the error as well as the parts I'm cutting outScreen Shot 2018-11-27 at 3.27.28 PM.pngScreen Shot 2018-11-27 at 3.27.14 PM.png
daniel_lyall
The tool will not be cutting all of what is selected the dog bones get missed, the 1/4in tool does not fit into the dog bone a 1/8 does and the error goes away.
Also in you set up the is nothing selected for the model body's.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
LibertyMachine
For additional fun, crank the tolerance down to .0005" and the cam path goes very wonky, lot's of large false cuts. Further, the profiles of the parts you are selecting are not true silhouette of the parts and you will not be satisfied with the results (lots of material cut where it shouldn't be). Turn on Stock in the Simulation and you will see it
Unless of course you know this already and it's intended...
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Marco.Takx
Hi @samgaddis,
First of all, it doesn't fit into the small corners (That's the message).
Second, you haven't selected the correct contour.
It is milling into the part at some places.
See the 2 issues below.
Marco Takx
samgaddis
Switching to a 1/8 bit worked like a charm. Thanks all!
