Message 1 of 11
When Doing a simple 2D contour milling and using the “ ramp” setting, when I set the “ bottom height “ to zero , from “ stock bottom “ the resulting G code has the Cutter going 0.040” below the stock bottom.
I have tried changing “ stock, bottom” to “Model, bottom”, with the same result.
how do I get the cutter to only cut to the bottom of the part, not .040 inches below the bottom?
thanks,
Chuck
