2D contour expected behaviour?
programming2C78B
Mentor Mentor
programming2C78B
is there a reason its going to the Clearance Height, not Retract when retracting between the two passes?
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
Dunno, can you share an example?
Seth Madore
programming2C78B
emailed
Laurens-3DTechDraw
Pretty sure it goes to retract height for different contours on the same height plane, when moving between different contour heights, it goes to the clearance plane.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
seth.madore
Yeah, what @Laurens-3DTechDraw said. When there's multiple depth selections involved, this is the expected result.
Seth Madore
