2D Contour Compensation
Message 1 of 18
I am trying to get my chamfer mill to follow a line exactly (without offsetting the cutter to account for the diameter of the cutter). I have been searching and everything I have read says that to turn the compensation type to "off" to get the tool to follow the line exactly right down the center. However, when I turn the compensation type to "off" it does the exact opposite. It offsets the cutter by a very large amount.Capture 1.PNGCapture 2.PNGCapture 3.PNG
Replies (17)
Message 2 of 18
seth.madore
That's odd. Can you share your file?
Right click on the file in the Data Panel and select "Share Public Link"
Seth Madore
Message 3 of 18
Captain-DJ
With 2d contour you can only use left or right to the contour.
You can try set an offset in options "stock to leave"...but i think you can try "2d projection" for thinks like this.
The dept of the tool must set on the 4. tab on the setting "axial offset" or so (i use the german version, don´t know the english word...and Fusion is not the fastest Software so i don´t want to switch to english) 😂
Message 4 of 18
seth.madore
This is incorrect, there most certainly is a compensation of "Off":
Seth Madore
Message 5 of 18
Ketherton21
ive used 3d project, or what ive done is just make my tool tip .001 or as small as it will go for engraving, that way its only left or right by .001.
Message 6 of 18
Thanks everyone for the responses. I have changed the file since I posted this question so I can't share it. However, I did figure out a solution/workaround. I didn't figure out how to keep the bit centered with a 2D contour, however, I did end up figuring out the "trace" operation. If you use trace you can adjust the axial offset to get the tool path to follow the contour exactly.
Message 7 of 18
I tried that originally. I had my tip set to 0.01". It was very noticeable since all the stripes are right there. One stripe might have had the tool on the inside of the stripe for both the top and bottom line of the stripe making the stripe noticeable thinner than the others.
I think for most things this would work fine but when you have several stripes of the same thickness stacked on top of each other it was noticeable. Although it may not have been if I set my tip width to 0.001".
Message 8 of 18
Captain-DJ
Ok, my mistake, there is an OFF option.
But if i use a chamfer tool it never moves at the middle of the tool.
Tip is set to zero or 0,01
@Anonymous
Yes i mean the trace operation. In german this will called: 2d projection
Message 9 of 18
DarthBane55
I duplicated your issue with the same result when the tool is defined as a chamfermill (bug?), but, I redid your tool as a "tapered mill", and OFF works as expected.  Maybe Autodesk can look into this, it looks like a bug.
Message 10 of 18
seth.madore
Yep, I'm seeing the same. I also find that setting the tip diameter to a very small value and using Computer Compensation also will keep it on center. It appears to be driving off the center in the case of Computer Comp and the full diameter in the case of "Off"
Seth Madore
Message 11 of 18
Thanks everyone!
Message 12 of 18
valery_osipov
Hello, guys! Is any fix expected some time soon? Thanks)
Message 13 of 18
Apparently not.  Fixing bugs is not nearly as sexy as adding new features. Autodesk seems to be copying the Google model of not giving a **** what their customers need, and focusing on what's exciting for the developers instead.
Message 14 of 18
da_fish
It's four years later and I am running into the same issue. Or am I doing something wrong? Could someone from Autodesk please advise???
Message 15 of 18
seth.madore
@da_fish what is it exactly that you're trying to accomplish, can you share more details and/or a file that shows your issues?
Seth Madore
Message 16 of 18
da_fish
Certainly,
I attached a file with some examples. In the file I am trying to scribe an X on the surface of the part with a chamfer tool that has a small tip diameter. Even though Compensation is set to off, it still compensates from the major diameter of the tool. But it should follow the line with the center off the tool.  If I use an endmill it does just that, as expected. But for whatever reason a chamfer tool doesn't.
Message 17 of 18
seth.madore
Use the Trace toolpath, that is the intended workflow for engrave type tools and centerline cutting.
The behavior that you're seeing with a Chamfer tool and 2D Contour is expected behavior, thus the recommendation for using Trace 🙂
Seth Madore
Message 18 of 18
a_winchcombe
Community Visitor
Community Visitor
I'm having the same issue. Using "trace" toolpath is not an appropriate solution for me as I am relying on the "wrap" feature that 2D contour has (and trace does not).
Also, https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-engrave-sin... specifically instructs us to use the 2D contour toolpath (note it does say 2D chamfer as a typo, the pictures and video show 2D contour).
