2D Chamfer
2D Chamfer
Jim_WrixonDXSZD
2D Chamfer
Jim_WrixonDXSZD
When using 2D chamfer, how should the tool be set so it cuts in the center of the cutter edge or near it, if that makes sense.
seth.madore
It's not a tool setting, but a toolpath. When creating your toolpath, you want to define a sufficient "Chamfer Tip Offset" to push the tool lower in the direction of the part. If using a 90 degree tool, this is simple math to work out, as the maximum Tip Offset you should define is half the diameter of the tool, minus the chamfer width.
For example: a .125" x 90 chamfer tool can only drop .062" below the surface. If you were cutting a .01" chamfer and wanted to use the maximum amount of flute, you would define an Offset of .05" and a chamfer size of .01".
That said, most deburr/chamfer tools are not ground to a sharp tip (although they appear as such to the naked eye), so your effective tool length is often closer to .055"-.058"
Seth Madore
