2d Adaptive WTF
2d Adaptive WTF
Message 1 of 19
2d Adaptive WTF
I've included some pics of a part where the 2d adaptive roughed out one slot fine but not the other. Then when it went to finish...well you get the idea. Here is the Fusion file that is fine. I included the code that I copied right out of the Haas when it happened. It all looked good in graphics and as soon as I posted it again the code was fine. You can find lines N26400 and N46065 on the WTF file.  If this is a mistake on my end I'd be happy to learn from it. Thanks guys.
Replies (18)
Message 2 of 19
Steinwerks
That's pretty bizarre, but when I post your protected toolpaths I get a full slot rough:
What year is the machine, and how are you getting it on there? I wonder if this wasn't a transfer issue. Do you have the original file posted from Fusion?
Edit: hmm, I noticed you post with N-lines, which I never do, but it sure looks like the code just got truncated somehow.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 19
That nc file is the one I copied right off of my 2016 Haas vf-4ss.  It is bad...it just left the rest of the adaptive code out.  It still retracted so it could finish though.  Yes I get a good program now too.  Just wanted to get it to some g-code wizards.  I'm not new but this could be a major crash if someone isn't standing there watching.
Message 4 of 19
Steinwerks
The problem is that this isn't a G-code issue per se, it's either a bug in Fusion, intermittent at best, or something happened somewhere along the processing line where the positional movements weren't passed to the post processor due to other unknowns. The retract is part of the next toolpath when onSection is called in the post, forcing a retract between operations, but we can see from the N-line ordering that nothing gets skipped according to the post, it just kept truckin'.
@angelo.juras or @fonsecr have either of you seen this before? It's a little crazy, and obviously a bit worrisome.
Neal Stein
Find me on:
Message 5 of 19
I sort of suspect a "ghost in the machine" with the 2d adaptive.  Figured I would through it out there and see if I missed something.
Message 6 of 19
angelo.juras
@Steinwerks - I will take a look
Message 7 of 19
Steinwerks
Thanks! I can't recreate it, but I don't have the same insight or access obviously.
@Anonymous Out of curiosity, what are your computer specs?
Neal Stein
Find me on:
Message 8 of 19
Message 9 of 19
angelo.juras
@Anonymous - On your Haas Mill, you are able to backplot it on the control. It will give you an exact representation of your code.
Did you try that and what did it look like?
I checked it on my end and this is what I get:
Message 10 of 19
Steinwerks
Well there shouldn't be any bottlenecks in that system!
Neal Stein
Find me on:
Message 11 of 19
angelo.juras
Here is my backplot of your WTF file:
Message 12 of 19
So what's wrong here?
Message 13 of 19
cj.abraham
I had a theory, tested it, and I think I found the answer.
I suspect that you posted the operation before the operation completed calculating. The generation time was suspiciously long for that operation, because I hit generate and quickly went to post code and realized it was still calculating. I tried to specifically time hitting the post process button while it was in the middle of calculation, and I could reproduce this every time.
But not before it gave me a warning!
So i think the solution here is for us to fail posting or not allow posting code while a selected operation is calculating.
Message 14 of 19
Interesting… I certainly wouldn't of finished it if it did give me some kind of a warning… I don't remember seeing anything. I've been posting code for a lot of years I would think I would be smarter than that LOL. So, it will let you finish posting code without a toolpath being finished?
Message 15 of 19
Yep....it seems to be possible.  I cant backplot from home (that I know of) what does this look like?  I did it way early to see what would happen
Message 16 of 19
Yes there is a graphics option and I will try tomorrow when I get back to the shop to see what it looks like
Message 17 of 19
One last thought that I was testing.  It seems that you can "protect" a toolpath before it finishes calculating also.  Not sure if you can get it to be half of a toolpath like my post but it will prevent it from finishing.
Message 18 of 19
Steinwerks
Try this online backplotter made by @xander.lucianohttps://ncviewer.com/
Neal Stein
Find me on:
Message 19 of 19
oh hey thats great thanks!!
