2D adaptive Failing
2D adaptive Failing
kmcgheeCMFPG
2D adaptive Failing
kmcgheeCMFPG
My 2D adaptive is failing every time I run it. I need some help on it please. File attached.
daniel_lyall
The tool does not fit in the slot
Change optimal load to 0.01 and minimum cutting radius too 0.001
Whenever you get this problem try with a tinny tool and if that works it will be the fit of the bigger tool, and yes the step over names is a bit different optimal load is the step over.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
MetalRipper_
Using 2D pocketing instead of 2D adaptive solves this problem. I've attached the altered file. Hope it helps.
Gokul Kannan
Making Parts at MetalRipper using Fusion 360
Youtube.com/@metalripper-
CNCexpert.com/gokul-kannan
