2D adaptive cleaning error
thekondrat
Message 1 of 20
thekondrat
Hello
I try maching simple pocket and have error:
Enabled feature flags: Additive-Tech-SLM adaptive-turn-roughing automatic-collision-avoidance drill-wizard milling-continue-rest-machining probe-geometry-strategy setup-sheet-viewer spun-profile-v2 strategy-blend strategy-inspect-surface strategy-rotary strategy-steep-shallow toolpath-trimming
Error: Internal CAM kernel error. Please report through your support channel.
What am I doing wrong?
Replies (19)
Message 2 of 20
seth.madore
Was this on Mac or PC?
I opened your file and saw the error. I then regenerated the toolpath (CTRL+G) and got this:
Seth Madore
Message 3 of 20
Marco.Takx
Same on my laptop.
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 4 of 20
thekondrat
On PC.
Generate dont work.
Message 5 of 20
thekondrat
Im trying reinstal Fusion.
It still dont work.
But 2D Pocket is work.
Message 6 of 20
seth.madore
Just to confirm, you have updated to the latest version, right? 2.0.8156
You can find this in the About in the top right of the screen
Seth Madore
Message 7 of 20
thekondrat
Yes. Im using 2.0.8156 version.
Yesterday everything worked fine.
Message 8 of 20
seth.madore
Win10 or 7? Is this the only file that's doing it?
Can you go through and turn off all the feature flags you have turned on? Those are found in the Preview section of your Preferences
Seth Madore
Message 9 of 20
thekondrat
Win10 pro x64
I have done it. did not help.
I try generate this toolpath on my second computer - it work.
On my primary computer it still dont work.
My old program with 2D apative, 3d adaptive  dont work on this PC.
Now i create new windows user account and install fusion.
It work in new windows account.
I need to somehow delete all the fusion files from the main account.
Removing files from the % AppData% folders did not help.
Message 10 of 20
I have the same problem after last update.
Message 11 of 20
thekondrat
Let me know if you can solve this problem.
I removed fusion from everywhere, from %appdata%, from regedit.exe.
It dont work.
Message 12 of 20
I fought with it all day long. There is no results. So i'd make a new user in windows, install fusion, then change user, find in browser fusion launcher executive file, make a link and use it. I have no more time to look for better solution of this trobble.
Message 13 of 20
Message 14 of 20
seth.madore
To all experiencing this issue;
By chance, do you have any non-ascii characters in your user name?
Seth Madore
Message 15 of 20
No in my case. User name - Anton. Before update everything worked fine.
Message 16 of 20
Hey, I have the same error since two days ago!! and I dont know what to do, I tried everything but it is not working!!
Message 17 of 20
thekondrat
My primary wibdows user is  "Валера"
Message 18 of 20
a.s.chernysh
Good afternoon!
You not only need to change the Windows user name, but also rename the profile.
I.e. after the last update of Fusion, there was an error related to paths in Cyrillic - or not ascii encoding at all...
For example, I solved the problem this way - I changed the user name, then renamed the Windows profile folder name - and tweaked the configuration file of the Fusion startup a little.
You can easily find how to rename the Windows user profile folder in Google.
Добрый день!
Вам нужно не только сменить имя пользователя Windows - но и переименовать профиль.
Т.е. после последнего обновления Fusion появилась ошибка связанная с путями на кириллице - или вообще не ascii кодировкой...
Я например проблему решил именно так - сменил имя пользователя, затем переименовал профиль виндовс и папку где хранится этот профиль - и немного подправил конфигурационный файл запуска Fusion.
Как переименовать папку профиля пользователя Windows можно с легкостью найти в Гугле.
Message 19 of 20
seth.madore
An update has just gone out that should address this issue. Please restart Fusion and let us know if the issue persists or has it been resolved. We apologize for the inconvenience!
Seth Madore
Message 20 of 20
thekondrat
It works. Thank.
