Updates to the Email Object for better workflow communications
I have two enhancements that would greatly improve our workflow communications using the email scripting object
Currently the Email scripting object has only three properties (To, Subject & Body)
It would be great to add an Attachment property most likely an array that could be populated via the script from workspace references to attachements in the system. - Great use would be to allow transmittal of pdf files to a supplier in an RFQ workflow.
Second (and not sure if this is possible) - allow for a default return email address (such as a company generic email address) to be the From address rather than the NoReplyAutodesk address.  This would only be used by Script generated emails - the standard workflow email should remain as is. You could define this address in one of two ways.
1. Setup in Admin a company default address that can be read via scripting
2. Get the user email address from the user information at the time the script is executed
BD
3 Comments
jared.sund
jdow
I would also like to see this not be just "noreply@????", but configurable (at least by scripting) to be any email address we specify.
I have a use case in which an on-demand email script is run for a record and sends to a user and I'd like for that user to be able to respond to the email directly back to the sender.
John Dow
aaron.tw
Status changed to: Archived
