Reporting Classifications
It would be very useful to add "classification" as a field in the report, as well as any related class fields (although simply the former would be a good start). I had assumed this would be possible when going with the newer class structure while setting up my tenant, and was pretty bummed to see it missing.
It seems as though if you can populate this field on import, you should be able to export it as well?
I know this is probably in the works already (since the reporting tool even lists "Classification Structure" with nothing populated) but I figured I'd post anyhow.
6 Comments
Hello!
In addition to the above, it would be great if these fields can also be added to the Workspace view and BOM view.
We currently have many fields in the classification structure but with no way of reporting/searching on it. This has hampered our efficiency in terms of navigating Fusion.
Thank you!
johnny.buccola
Agreed!! I've spent tons and tons of time populating and managing all of these class fields and the class tree, and it's still basically useless after it being featured for something like a year now. I wish I'd instead created my own classification system instead, as item details fields. Instead, I just have to sit and wait.
I am very surprised that this is not a reporting feature that's already in place.  The field exists when I try to run a report for the Evaluations items, so why is it not there for the actual Items?
Like Johnny mentioned, the fields are of no use if they're populated by we can't really use the fields for our reporting purposes!  I need to create my own tracker or do dumps of all the items I want, combine the data then filter on the fields I need; too much hassle!.
Please implement this feature ASAP....
thank you!
gasevsm
Fiona, we are reviewing adding this request. Will update the forum once affirmed.
benderk
Thank you for submitting your idea. Have you tried the Modern Interface lately? We request that you review your idea in the context of the Modern interface. If your idea is not addressed, we invite you to create a new Idea in the context of Modern so that it can be addressed accordingly. Sincerely, Keri Bender | Global GTM Business Strategy Manager, Product Lifecycle Management
benderk
Status changed to: Archived
