Replace a part in multiple BOMS
Say an user want to replace a
       "Steel Nut-8" : rootDMSID=1234
        With
       "Plastic Nut-8" : rootDMSID=5678
in multiple/all boms.
Current flow:
1) User has to replace the part in the working version of every assembly where the part (Steel Nut) appears. This can take for ever.
2) Make a change order with all these assemblies and release it.
Proposed workflow:
1) Make a change order and click on "Replace part" in the "Affected items" tab.
2) Select the "Outgoing" and "Incomming" part.
3) Select the BOMs that need to be changed -OR- select ALL
4) Release the change order.
Im working on "Affected Items" as part of my notmal work and will add more technial details as i go along.
Attached : a PPT
5 Comments
gasevsm
Greetings, Thanks for the comments. We'll review be request in detail and follow up if there are further question or comments. Presently you may do the following; - add the steel nut to an ECO and - within the tab run the 'include related (BOM) items' action selecting all (direct) parents and they would be added to the ECO. - Then visit the parents and modify their BOM to replace with plastic nut. - Add the plastic nut to the ECO as well. - Submit for CCB and if the approval board agrees, release the change completing the use case. Regards,
ramnath.gopalan
tks martin for the comment, I thought you were on leave Smiley Happy
I was not aware of the feature "include related (BOM) items" thats very useful.
I still feel a "replace" option is useful
1) We remove the manul work of deleting the old part , every where it is at the First level
2) We can show the NEW-OLD part as replaced in BOM-Compare (This is not same as Deleting a part and adding a new Part in a BOM). This is technicall much tougher though Smiley Frustrated.
Simple Delete-Insert in multiple BOMs should be easy as its basically an existing feature, we are just spreading it to work on multiple BOMs
nguyentru
Hi Ramnath,
We appreciate you taking the time to write and submit your idea on the Idea Station.
As Martin mentioned, our Product Team will review  your request and will add to our future enhancement list.
Thank you,
Trung
benderk
Thank you for submitting your idea. Have you tried the Modern Interface lately? We request that you review your idea in the context of the Modern interface. If your idea is not addressed, we invite you to create a new Idea in the context of Modern so that it can be addressed accordingly. Sincerely, Keri Bender | Global GTM Business Strategy Manager, Product Lifecycle Management
benderk
Status changed to: Archived
