"Restrict "Relationship Tab" options to latest versions" suggestions
The "Restrict "Relationship Tab" options to latest versions" setting in Workspace Relationships does two things:
  1. Limit selection of revision-controlled items to Latest Version only, making the "All"/"Latest"/"Working" selection filter in the Add Relationships box redundant
  2. Controls relationships behaviour when revision-controlled items increment a revision
On 1, I have the following suggestion:
  • Grey out and disable the "All"/"Latest"/"Working" selection filter in the Add Relationships box, when "Restrict "Relationship Tab" options to latest versions" is ticked
On 2, I have the following suggestions:
  • Update the help documentation (link) to describe all scenarios, including:
    • Behaviour when a relationship is added to an Unreleased working revision
    • Behaviour when a relationship is added to a Production working revision
    • Behaviour when a relationship is added to a Production revision
    • Behaviour when a relationship is added to a superseded revision
    • Clarify the behaviour when the relationship is Uni-directional (e.g. is it uni-directional from the source item or the target item?)
    • Describe a corresponding linking pick list setup to match the above behaviour - we often use selections in linking picklists to revision-controlled workspaces to create relationships via scripting. It would be preferable for the revision in the picklist to synchronise with the revision with the bi-directional relationship without manual intervention.
I have had to spend hours trying to work this out and I'm still not sure of it...
1 Comment
amitabh_verma
Status changed to: Gathering Support
Hi @AstroRossD
Thanks for your suggestion.
We will review and get back to you.
Amitabh Verma
Principal Product Manager | Fusion Manage
