Production Revisions following ASCII II standard outlined in ASME y14.35 should not Rev from 9 to a : but from Rev 9 to Rev 10.
Currently The lifecycle editor allows for the increment of Version or Revision.
Using Version applies the Decimal Characters while Revision applies the Printable Characters from ASCII II.
If a customer requires both numeric and alpha in their Production Rev levels and issue arises if the Rev needs to go from 9 to 10 where it will auto increment from 9 to a : since ASCII II Printable Characters cycle through the special character set after 9.
Can the logic be added to Fusion Manage to it can function similar to Inventor which has the logic to rev from 9 to 10 in both Revision and Versioning.
1 Comment
amitabh_verma
Status changed to: Accepted
