PLM - Tab “Where Used” customizable
It is possible to customize the “Bill of Materials” tab by creating different views. It would be good to do the same thing with the “Where Used” tab (add/remove columns based on the workspace properties).
Sylvain
1 Comment
PLM-Sylvain.Bailly
It is possible to customize the views and then select the needed one into the “Bill Of Material” tab (as you can see into the picture below).
Each department of a company has a different need/usage. This feature is a powerful and interesting tool to help PLM users doing their job.
If we can have the same for the “Where Used” tab, it will be great. As explained in my previous post, a section must be added into the configuration of the workspace for the “Where Used” tab. Like that, it will be possible to customize the views and then, use it in the items.
Sylvain
