Pivot value update
Pivot value update
If I change the pivot value in Work Space A is not updated in Work Space B until I actually change the derived field  into another value. The derived field will change but the pivot wont.
I would like that the pivot value updates as the derived value does
Attached is how is happening right now.
4 Comments
What I'm trying to do is data integration. That the data that I have in the  work space A be the same that I have as a derived field in the work space B. And if I change in WS A, changes in WS B. This shouldn't be static.
jared.sund
This is part of the feature spec for derived fields, that is to provide options on how changes propagate. The currently functionality is defined that updates are only performed on explicit update/edit by the user. There are plans to add additional functionality to allow updates to propagate without user action. I'll add this idea Station request to our feature requirements to make sure this behavior is covered correctly.
Thank you for your quick response.
I'm looking forward for this new feature. I'll like to receive updates regarding of the status of this subject.
aaron.tw
Status changed to: Archived
