there should be a selection in a picklist to Enable or Disable a Value. currently if I want to remove a value from a picklist I would have to delete it causing the value to be removed from all historical records. deleting a value in a picklist causes audit history problems. a real change control system would allow you to do that. so having a selection to disable it while keeping it on the list would be great. this will also allow you to re-enable it in the future if needed. I've had to resort to creating all picklists in a workspace and creating an enable/disable check box and a second picklist pointing to the workspace with filters for only enabled. this is clunky and unnecessary if there was one selection within a picklist. yes I have tried Modern UI and there is no difference with Classic vs Modern for Admin functions so please do not respond with that canned reply.
