We need a controlled, structured way to make changes to released revisions. The primary use would be to make clarifications or administrative corrections on technical drawings that are attached to an item record. Another use would be to make corrections on the Item Details tab in a locked section.
The primary requirement is to be able to open a particular version for editing via a workflow. As far as I know the only solution today is to use the "Override revision control locks" permission which gives access to all records in a workspace and does not have a traceable workflow associated with it (the workflow might contain an approval or review step as well.)
I thought maybe creating a lifecycle transition that neither increments version nor revision might do it but no luck because that only opens up the working version for editing, not any of the released versions.
Thanks.
Joe Hendrickson
