This idea was already raised here but I provide an update for the Modern User Interface.
1/ About the first point, apparently you have removed the functionality in the MUI. The icons "+" and "-" have disappeared. Could you please add a “+” to do an 'expand all' and a "-" to 'collapse all' the levels?
2/ Could you please add the button “Add” in the tab “Where Used”? I have seen that now, with the MUI it is not possible to use the icon "Create Relationships" from an item as it was possible in the Classic UI. If I miss something tell me because I cannot see the icon anymore. In the attached picture, you can see in the green rectangle the icon on the Classic UI that I am talking about.
3/ new - in the Classic UI it was possible to see all the links between the workspaces with an icon (red rectangle in the picture attached). Could you please include it in the MUI? It was useful.
4/ mew - In the MUI, from an item I have access to 2 arrows in the top right hand corner called "Previous Item" and "Next Item". There is a logic between the items or it shows only random items of the same workspace?
Thank you,
Best regards,
Sylvain
