The current environment for the scripts is not userfriendly, lot of functions are missing and each time we are going back to the list, the sections are expanded... This is time consuming and this is not so easy to have an overview of the various scripts linked to a workspace.
So, could you please consider these improvements for the Scripting Environnments:
-Delete the sections and add a new column for the script types,
-Add the latest author and a date,
-Add a possibility to create the views,
-Add a possibility to sort and filter in the scripts columns,
-Add a search function based on key words, any string, author, date...,
-Open any script, search results in a new tab (This is to avoid closing / opening lot of time the same scripts when someone wants to compare something).
AN example of what we can have:
In addition, could you please check if you can add also:
- A possibiliy to open a new tab when double clicking on the function,
