Import Improvements
Import Improvements
Imports have several limitations affecting usability and functionality, which steepen the learning curve and/or generally prevent ease of use:
  • Revision, Lifecycle State, Release Date parameters have different names when exported from a view or report (Release Letter, Lifecycle, Version Timestamp) so always need to be mapped manually. Please make these parameters have consistent names across the system.
  • Descriptors of linking pick list items where the last field has no data are displayed across the interface as ending with " -", this is sufficient for a successful match, but data is only imported if the string ends with " - ".
  • The "Done with Errors" report when an import fails is hard to view (xml file) and never contains useful data.
  • If an import times out, this is not communicated to the user.
  • "Message" and "Row" columns in the Errors/Problems list must be adjusted to display their content on every import.
  • When Running an import, the user needs to close the page to return to the import list to see if it was successful
  • The Imports list is sorted by ascending order, so the user has to scroll to the end of the list every time to see the status of the latest report
  • It is not possible to filter the Imports list
  • On an import with a large quantity of columns, the column headers and column data become slightly misaligned
  • Date format for Release Date/Version Timestamp is sometimes not automatically converted to yyyy-mm-dd format
  • Import column widths don't automatically adjust to content
  • Excel files directly exported from Reports are in html format, which can't be used for imports until saved as xlsx files. Surely it's possible to export an xlsx format file automatically.
  • Descriptor format is inconsistent for revision controlled items in linking picklists; custom views and import format is "descriptor REV:w" while "descriptor [REV:w]" is the format in links. Why can't this be consistent?
  • Imports to latest versions do not update working versions automatically, there should be a setting to enable this, otherwise the import needs to be run twice, once for the latest and once with the Revision, Lifecycle State, Release Date parameters deselected for the working version.
  • BOM imports are only possible when parent and child items are from the same workspace
Solutions to any or all of the above would represent a significant improvement in usability. Forum, please feel free to add to this list below.
