Creating a BOM with the same item used multiple times at the same level
We have the need to produce a BOM that can have the same item used multiple times at the same level rather than increase the quantity, see below:
Imagine a simple assembly with two children as per fusion can currently produce:
  • Machine Assembly                                                        x1
    • Bracket        x2
    • Plate        x3
With the above it is only possible to increase the quantity of each item.
What we require is:
    • Bracket        x2
    • Plate        x1
    • Plate        x1
    • Plate        x1
Adding further child items can be included as new lines not increasing the quantity. I’m imagining a toggle (or similar) on the place component dialogue that allows the user to pick either increase quantity (the default option) or add new line item as above.
The reason for this is to add extra property information to a BOM view such as location ID’s or similar for the individual components, If the quantities are grouped then this information cannot be accurately maintained. I have seen workarounds that use the grid to maintain this data, but this makes the syncing to ERP and ongoing maintenance of the BOM overly complex.
6 Comments
emre_sahin9PU3F
I don't think this topic will be a major focus for the Fusion developers. As a solution, they might send you a video about using Excel or direct you to a company that offers paid third-party software solutions.
muratP4X5Z
In fact, it is a subject that every company in the manufacturing sector needs. I hope that a development will be made on this subject as soon as possible.
joey_baughman
We have several clients in need of this today and it will only become more common as Vault and Fusion Manage integrations increase in popularity. We have work arounds but they're not the ideal state. This functionality would be helpful for managing BOM variants, configuration information, manufacturing operation sequences, etc.
stefan.risslegger
Also in our daily business we have the need of multiple used items in the BOM. E.g. use items with quantity meters in different lengths, cables with different positions and many more use cases.
This would be great to have in future!
If you add a new BOM Level in beetween you can have the same item multiple times.
I did that in some Plant Design PLM Projects.
If you change than the BOM of Level 0 1ETG to Flat BOM View PLM calculates the Sum of all equal Items Quantities automaticaly.
Example for Test Import in Items and Boms Workspace:
There exists a Autodesk University 2024 Presentation of this great idea.
vladimirJ6NAH
New Member
Yes, this is a huge problem. For the correct generation of assembly drawings, you need to activate a specific part… but if there are 50 identical parts in the assembly, it would be logical to place the part into a parent component, which makes this component unique in the BOM. Otherwise, you might have to reselect them in the main tree to add them to the drawing… and considering the lags when editing drawings, this is not an option.
The only way is to assign a name to the component… but what if it comes from the library…
I guess I’ll just go back to SolidWorks.
