Show only
Search instead for
Column resizing into Factory Design Suite properties
Everytime I open Factory Properties, I need to enlarge the first column (please see attached picture). It would be great if you can make it automatically resize with the lenght of the text.
I found this problem very annoying also, pretty much all the factory blocks that has a big text on the left column needs to be adjusted every time you made some editing. It's absurd to keep doing this while I'm on the time crunch!
Greetings, you have added a post to a forum idea station targeted for Fusion Lifecycle, a PLM tool. Not sure where you intended to add this, but please check the other forums dealing with factory and inventor. Regards,
