Could you please develop a function to ‘capture’ the tenant name? It will be very useful.
For the moment, the only solution that we have is to declare a variable in a library script and call this variable in the other scripts.
After each migration of our Production server to our test server, we are forced to update this variable manually but if we forget to do it, huge problems can happen like update of our ERP Production database with data which are coming from our PLM test server…
Here is a post that I have created to have a solution to this issue:
https://forums.autodesk.com/t5/fusion-lifecycle-forum/action-script-check-tenant/td-p/7753498
Here is an old post on the same topic:
https://forums.autodesk.com/t5/fusion-lifecycle-forum/determine-tenant-environment-during-script-exe...
As explained in the second topic, a senior solution architect tells that it is not possible because of the “cloud infrastructure involved” but we must have a flexible solution which fit to our needs.
Thanks!
Sylvain
