To whom it may concern,
I think this idea would be simple to implement: add a Cancel buton in the Advanced Print View dialog.
Once you go into this dialog to add, edit modify or consult, there is no way to go back to where you were before.
Yes, you can use the back button to go to the previous page, but this is only useful when you went in and did nothing.
PLM has that functionnality in the Print Views, so why not do the same in Advanced Print Views.
It's ironic because it's called Advanced, yet the environment is not...
Marc S.
