Show only
Search instead for
I need the ability to specify a custom rev scheme. I want my rev scheme in PLM 360 to follow the same standard that I created in Vault. It makes sense to me to have all my Autodesk products in revision alignment.
I see that this was accepted, but wanted to comment further...
I would and my customers would also like this capability.
At least have the ability to specify the Version numbering scheme and also specify the Revision scheme starting values.
Valid starting values need to be 0 "zero", "blank", "-", "IR", etc. for either schemes. My customers want/need the item revision values to match their existing scheme otherwise it all out of sync and very confusing to end users.
This has been a point of frustration with my customers.
This isnt available in the product yet. Ability to switch over to manual revision scheme still exists, but this is freeform revisioning and isnt following a sequence of a predifined custom revision scheme. Thank you for the followup and be sure to check this area foe updates on this topic. Regards,
Thank you for submitting your idea. The timing isn't quite right for this to be a priority for development consideration. As such, we will put this on the back-burner to revisit at a later date. Please continue to comment and add your support.
Thank you for submitting your idea. Have you tried the Modern Interface lately? We request that you review your idea in the context of the Modern interface. If your idea is not addressed, we invite you to create a new Idea in the context of Modern so that it can be addressed accordingly.
Sincerely,
Keri Bender | Global GTM Business Strategy Manager, Product Lifecycle Management
