Add file properties and arrange columns in attachments
Dear Autodesk,
If we have a look on the attachments of an item, which has been synced from Vault Professional, only the filename is visible, twice, also in the title and it is hard to identify what origin file it is. We are using heavily custom properties where also a document number is defined.
Our wish is to first of all sync also the file properties to Fusion Manage and to have the possibility to modify the columns with it, to show e.g. document number, revision, English description and other properties which are mandatory to identify the correct file.
Thank you
