Security.searchUsers(userProperties); Security.searchUsers({key:value, ...})
I'm not sure that if Security.searchUsers(userProperties); Security.searchUsers({key:value, ...})  really works. Can anyone provide working sample script use this feature? Should I use lastName or LAST_NAME as key. the following codes do not work.
var usersFound  =   Security.SearchUsers({lastName:'vuong'});
var usersFound  =   Security.SearchUsers({LAST_NAME:'vuong'});
Ming,
This is the correct usage:
var usersFound  =   Security.searchUsers({lastName:'piggee'});
println(userFound)
Array [ID:piggeej userStatus:Y firstName:Joseph lastName:Piggee email:[email protected] workflowNotifyPreference:A batchNotifyPreference:A]
This will return an array of the properties for the user(s) your looking for.
i can get the array back now. Thank you.
