Scripting; Send print view of workspace via email.
Let's start with, I'm new to scripting........
I'm trying to send print view (of details tab) via e-mail;
My Script;
var email = new Email();
email.to = '[email protected]';
email.subject = 'Deviation Has Been Approved';
email.body = getPrintView('RecInsp');
email.send();
Print view has been created (see image);
When testing the script I get the following error;
There is an error in the script on line 5, column 0. Wrapped java.lang.NullPointerException (PC_dev_req_nofification_insp#5)
Any help would be greatly appreciated!
michelle.stone
Quick question - did you set it up as a Basic Print View or Advanced Print View?  I did a quick test with your code (just changed email to mine so I didn't spam you!!) and it works when the print view is set up as an Advanced one.  I ran it as an On Demand script for quick testing.
APV:
Michelle Stone
Technical Marketing, PDM & PLM
Autodesk, Inc.
tony.mandatori
There was a bug with getPrintView where the generation of the printview would trigger a validation script.
To avoid it, i used to copy the text in the printview into a string variable and then use that for the body of the email.
Hi Michelle,
Thanks for the quick response. Turns out I did not have an advanced print view set up. Added one (RecInsp) but still getting the same error.
Hi Tony,
Gave that a try, same end result, "There is an error in the script on line 2, column 0. Wrapped java.lang.NullPointerException (RECINSP_DEV#2)"
Here is my script
var emailbody = getPrintView('RecInsp');
email.body = emailbody;
email.send();
tony.mandatori
Avoid calling getPrintView altogether... because it tries to run unnecessary validation.
Copy the report source code (by clicking the gear icon in the report setup) into the script instead.
Does that help?
