performWorkflowTransition on revisioning item
Aron_Thorfinnsson
Aron_Thorfinnsson
Hi, I have a revision ctrl WS where I want to be able to check a box on an item release it via onEdit script.
var statusUnreleased    = "Unreleased";
var actionRelease       = "Release Doc";
var actionNewVersion    = "Revise Doc";
var wsLockRev = 'WS_LOCK_REVISIONS';
lock();
function lock(){
if(!item.LOCK_REVISION || !item.descriptor.revisionList[0].working) return;
var newLockRev = createItem(wsLockRev);
var wfItem = newLockRev.workflowItems.addItem({RELATED:item});
var state = item.descriptor.dvi.lifecycleState.stateName;
wfItem.lifecycle = (state === statusUnreleased) ? actionRelease : actionNewVersion;
newLockRev.performWorkflowTransition(4218); //release revision
The code everything it is suppose except the revisioning item hasn't been able to grab the revision from the item I am passing through.
is there a workaround or a way to achieve this?
Aron_Thorfinnsson
Philip, with some help I managed to get this to work with this:
//Documents Non Rev Ctrl by us but where we want to keep track of revisions [onEdit]
prepareRelease();
function prepareRelease(){
var newLock_Prop = [];
newLock_Prop.DATE = new Date();
var newLockRev = createNewItem(wsLockRev, newLock_Prop);
newLockRev.performWorkflowTransitionByCustomID("SUBMIT");
//Lock Revisions [onEdit]
//Revisioning WS onEdit:
if (item.descriptor.workflowState === "In Progress") {
    item.performWorkflowTransitionByCustomID("SUBMIT");
} else if (item.descriptor.workflowState === "auto") {
    item.performWorkflowTransitionByCustomID("COMPLETE");
//Lock Revisions [wfActions]
//Revisioning WS wfActions:
switch(customTransID){
	case 'INITIATE':
	item.TEST = Math.random();
	break;
	case 'SUBMIT':
	item.performWorkflowTransitionByCustomID('COMPLETE');
	break;
	case 'COMPLETE':
	break;
philipfrench
Nice work. I did not know you could do this in a single step. It never used to work.
I will remove my original comment, because that was not correct.
