Issue with V1 API Logging in (Error 410 - Gone)
mibrahim01
mibrahim01
I am having trouble logging in to the v1 API via Postman (v7.36.6 latest). I keep getting a 410 - Gone response. The last time I used Postman(over a year ago) it was fine, all the details were saved from my last request. I checked the API guide and everything looks correct. Nothing really has changed (account, user id and password)
Does anyone have any ideas?
  • API
philipfrench
FLC V1 authentication is no longer supported.
You have to use V3 (Forge-based) authentication.
After you authenticate you can use both V3 and V1 FLC API calls.
So, the V1 FLC API is still available generally (V3 is preferred).
However, specifically the V1 authentication (/login) API is no longer supported.
In the online help, browse down to REST API v3 Reference --> 2-legged OAuth Tutorial
(Ignore the 3-leggged. It is the 2-legged you will need).
mibrahim01
